Yes I have. I've always listened to music and movies 50/50 so I've always had an integrated amp with ht bypass connected to every AVR I've owned.
2-channel music is warm and mellow as the Denon is not used, my source connects to the MF amp. But movies are tiring after an hour or so using the Denon. I'm not sure if it's because of the Denon sound or its lack of power at high volumes. My room is acoustical treated and as said earlier, music sounds amazing.
Best to contact Colin, he can give you a definitive answer and is very helpfulSo the twin modules are spec’d exactly as a single module.
The website seems to be a little confusing with the module layout. Looking at the rear panel of these 5 channel options, it only shows the 8 channel version which is bizarre, and the rear panels are different between the black and silver casings.
I think they change the rear at some point but i could be wrong
This is how it is for 5ch
I found myself getting into the subject of pre out voltages and gain etc, thankfully the 8012 appears to be pretty good on this point.
Is this of interest to you Kev? Not sure if you've seen it.
What’s speakers did you end up with Kev?
Let me know when you’re falling off the stone!I'm on a stepping stone for now and have what you have
