Noontec V8 NAS
Discussion in 'Video Streaming Boxes & Services' started by Big John, Feb 21, 2013.
  1. Big John
    Big John
    Feb 21, 2013
    3
    Hi, please be gentle as this is my first venture in to your world and I am hoping some will know the answer to a problem I have with my Noontec NAS V8.
    I bought this in December 2011 and use it for storage of files, music, pictures and films, the usual stuff. When I first got the unit I could also look at Youtube, and internet TV. I recently had a sort out of equipment and rewired my setup. On checking all my connections to the Tv,DVD,Humax etc I thought I would also check out the running of the V8 and all is well with storage and LAN connection to my Win 7 PC but there seems to be a problem with connecting to the Noontec server as I can no longer get Youtube or internet TV. It is getting the weather stations and text news with the correct date and time so I know the internet is working on it.
    Any suggestions apart from making it a permanent "brick" paper weight! :lease:
    Update:
    I have found out today that my problems are all to do with Noontec shutting down their server for access to the Youtube etc. on the V8.
    Any one converted a V8 to windows or Nas4free?
  2. next010
    next010
    May 29, 2005
    10,797
    163
    +2,113
    The Noontec V8 is a Realtek 1185 based media player it seems so that means your stuck with whats on it.
    You could possibly use a PC DLNA server like Serviio with some plugins for websites like iPlayer, though for something standalone your probably looking at a new box like a WDTV Live Hub for instance which has Youtube built in.
  3. Big John
    Big John
    Feb 21, 2013
    3
    Many thanks for your help.I did look at the WD Live before I bought the Noontec but as always I went with the majority who said the noontec was better.
    However, when I look closley at the spec etc of the WD Live it does say "These streaming services may be changed, terminated or interrupted at any time."
    I think I will keep the V8 as a NAS as it works very well and when the money permits I might got for a Shuttle XS35GS V3 and use to access the web. It is small enough to sit behind the TV.
    Again thanks for your help.
  4. next010
    next010
    May 29, 2005
    10,797
    163
    +2,113
    A cheaper option might be an Android HDMI stick like one of these, provided your okay with using a wireless mouse or something similar on it, that will get Youtube (which isn't going to disappear from Android) and some other services though not all Android platforms are 100% compatible with all Android apps.
    It will also handle common video types & you can share out a USB drive via the various samba file server apps on Android store.
  5. Big John
    Big John
    Feb 21, 2013
    3
    What a wonderfull bit of kit/idea, I never knew such a thing existed.
    I already have mini keyboard with wireless connection which works very well.
    I will have a good read of the rikomagic page and their equipment and may come back with a few questions if I may.
    Thanks.
