thetargetarcher
Established Member
I still do not know which soft mod is installed on my Xbox as no-one has replied telling me exactly what files to look for using the File explorer on my emulator disk. I do not have any of the SD,007 or mechassualt game saves on the hard drive BUT the xbox plays the emulator disk and backup games.
My new question is this:
Is it okay to install a new soft mod using the soft mod kit which is being passed around in the other thread? My Xbox states:
K 1.00.5838.01
D 1.00.5960.01
Would it be safe to do this and is it basically the same as when you re-install Windows on a PC?
I was in Game earlier today and I purchased as part of their 3 for 2 offer a copy of Tom Clancy's Splinter Cell (2002) which was priced at £3.99. On the back of the box it states 9 missions. It is not a classics or a best of box. I assume this is the correct version and game used for soft modding. The front picture is of a special forces person kneeling on a grate in the floor with green light coming up from the grate.
Can I install XBMC and not bother with putting a new soft mod on my Xbox or am I better off putting a new soft mod on and then installing XBMC?
Apart from the Splinter Cell game, I also have a 8MB Thrustmaster memory card and a cable which is both a controller extension and a Xbox controller to PC USB lead meaning that the Xbox controller can be used on the PC.
Do I need a Xbox cross over cable from somewhere like Ebay? Does this simply just plug into my Xbox and the Network card on my PC?
Sorry to post a long message. I just want to be totally clear on soft modding, XBMC and the DVD region free program.
Thanks for your help.
K 1.00.5838.01
D 1.00.5960.01
