noob! SUBWOOFER QUESTION (help?please)
Discussion in 'Subwoofers' started by dummie sub, Apr 22, 2005.
  1. dummie sub
    dummie sub
    Ok so I have a potentialy challenging question... Im very new to all this... so bare with me...
    Ok heres my problem/question... I have a stereo... a regular not complicated cost like under $200 stereo cd plyer and cassete player and two speakers... What I want to do is this... I have a spare subwoofer... and I was wondering if there was ANY way that I could hook it (the sub) to the stereo... even if it means doing a little custom job or something... im just really curious... thank you in advance for anyone that would bother to answer me or call me a flippin moron... ^__^
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    If it's a passive sub, or an active sub with high level (speaker) inputs, it should be possible. Think we'd need more detail of what the sub is and what the amp can output eg has it a spare set of speaker outs?...PJ
  3. dummie sub
    dummie sub
    *laughs* AMP?pfft Ihave no amp...or at least Idont think I do... AND I dont have a reciever... or the speakers that came with the sub... Ionly have the sub becuase my brotherfried the reciever and the speakers...what i have is your simple tipical stereo... (off brand too *laughs* ) cd player... cassete player... and radio... thats it... its pretty loud... but no bump if you understand the vernacular... and the sub is "RVC" as far as I can tell I cant tell you specifics... simply because I dont know...
    once again... I thank anyone that would bother to reply or tell me im a fool for trying..
  4. JBL 4645
    JBL 4645
    Apr 20, 2005
    127
    16
    the sub bass then use the high-pass outputs on the sub bass going to the loudspeakers…
    Play a musical tone that’s down to has low as 30Hz or 25Hz by turning the volume up on the sub bass and the main volume on the amplifier…and the keep the sub bass near to the loudspeakers if at all possible…now that should work hope all goes well good luck… :thumbsup:
    Ashley….
  5. dummie sub
    dummie sub
    I'll try that.. thak you for your help... i'll post back my results...
    much thanks...
