Noob question. Sorry! "Optical Out"
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ResB, Mar 27, 2006.
  1. ResB
    ResB
    Feb 10, 2004
    UK
    +7
    Does the Optical Audio Out on the back of the Sky HD box provide the 5.1 sound. I've never used the optical to be honest and have always connected through Coaxial. :lease: :rolleyes:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Yes it can carry any audio that is broadcast.
    It does exactly the same job as a coaxial digital audio link does on other products:)
  3. Bal
    Bal
    Mar 10, 2002
    2,196
    Berkshire
    +320
    Yes it does although the HDMI should also carry multichannel sound if your amp can support it and one less cable too.
    HTH
    Bal
  4. ResB
    ResB
    Feb 10, 2004
    UK
    +7
    Thanks guys. I appreciate it. I thought so but wasn't entirely sure. I was contemplating replacing my Pioneer VSX-C501-S with a new receiver so that HDMI could be used for both my DVD Player and SkyHD. Might be the best option for me.
    Cheers again. :thumbsup:
  5. SAH
    SAH
    Feb 28, 2004
    1,721
    48
    +75
    Can anyone suggest a suitable amp and surround sound set-up for SKy HD.
    To be honest, the fewer cables the better, I'd even consider some sort of virtual surround set-up if it offered 70%+ of the sound quality.
    Value for money is more important than the best quality.
    Any help much appreciated.
  6. Clara
    Clara
    You'll get your 5.1 via the HDMI according to Sky!
  7. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    HDMI carries audio so yeah they are right but of course you need an amp which accepts HDMI and they are still thin on the ground and most people with 5.1 systems have amps which accept optical or coaxial digital which is just as good.
  8. gritbox
    gritbox
    Jan 12, 2006
    823
    anyone tell em what optical audio looks like on the back of my telly? ive got a 26" sammy r51, take it it hasnt got one?
  9. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    TV's usually don't have optical audio.. not a lot of point as there's only two speakers on a TV right next to each other (they don't have coaxial digital either).
  10. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Best to ask that in the appropriate forum to be honest, far more likely to get attention.
