Noob question on Freeview reception
[email protected]
Hi all,
A total noob question here! I have installed a loft-mounted digital aerial recently. it's a cheap affair from Argos but the analogue channels 1-5 are crystal clear without signal boosting. I just wanted to know if this good analogue reception is any indication of whether the quality of digital reception is likely to be good also or whether there is little correlation between the two.
Many thanks!
Garry
pjclark1
Yes it is.
jameslindsey
Should be OK.
I also have a cheapey aerial in the attic. CH5 is a little ropey on analogue but perfect on digital, If I move the aerial slightly (5 degrees or so) I get perfect analogue but the CH5 muliplexes then dont work. Never use analogue though so gone for the digital position.
