noob question about sacd
Discussion in 'Music & Music Streaming Services' started by av addict, Aug 2, 2005.
  1. av addict
    av addict
    Jan 27, 2005
    2,207
    +164
    noob :clap: why has my dvd player got 6 channel audio out sockets if it does not play sacd discs-i have these on my amp as well can i not connect both up to give me sacd sound or should i stick with my coax cable-thanks sparkytoon
  2. Ronm1
    Ronm1
    Your sig list the panny 97...it is a dvd-a player so it has the other Hires format
  3. av addict
    av addict
    Jan 27, 2005
    2,207
    +164
    yes i use coax to listen to dvd-a would six channel be better then and would i be able to get dts sound when watching dvd discs movies from six channel cheers
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    DVD-A is only available via the 6 analogue leads on mosy DVD players/receivers. The exception being Denon link and Pioneers iLink.
    If you listen to a DVD-A with only the coax connection then you only hear the DD/DTS sountrack and not the high res DVD-A track.
    To get the best of both worlds you should use digital coax or optical and 6 phono analogue leads. Use the digital for DD/DTS films etc and the analogue for DVD-A.
    Mark.
  5. FeisalK
    FeisalK
    Jun 9, 2005
    375
    KL
    +21
    you can compare the DD/DTS decoding between your player and receiver if you conect the 6ch analog outputs.
    Anyhow, since the S97 has HDMI you might want to think about a HDMI capable receiver on your next upgrade then you can do away with the 6ch analog for DVD-A
  6. av addict
    av addict
    Jan 27, 2005
    2,207
    +164
    cheers guys thanks for the info :hiya:
