Noob question about region 1 discs?
Discussion in 'Movie Forum' started by stu1972, Nov 12, 2004.
  1. stu1972
    stu1972
    Hello peeps,
    Heres my dilemma, a Panny TX32PD30 set with Pal / NTSC progressive and a Panny SCHT870 DVD cinema box with NTSC progressive output only. Is it really worth buying region 1 discs so i can get a progressive signal or is it worth just sticking with region 2?
    Is a "native" NTSC signal not as good as PAL anyways due to less lines?
    Any help would be greatly appreciated
    Stuey :)
  2. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,059
    +169
    It is definately worth getting region 1 (and 3 and 4). Whether you prefer PAL or NTSC is up to you, it is not as clear cut as which is better - They both have +s and -s
  3. stu1972
    stu1972
    Cheers mate,
    Will have to spent the £30 to get it remote unlocked now :eek:
  4. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    The difference in the number of lines is not a major issue. More important is mastering of the disc.
    I had a R2 copy of "Dead Ringers". I replaced it with a R1 as he PQ was vastly superior because of the care taken with sourcing and mastering.
  5. lee789
    lee789
    Nov 21, 2003
    452
    +3
    Plus if you buy a lot of dvd's you aren't stuck with just uk releases, you can buy from anywhere which can in some cases save money :smashin: .
    And buy early.
