Noob Needs advice please
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Captain Carling, Aug 26, 2006.
  1. Captain Carling
    Captain Carling
    First of all i would like to say hi to all you clever people :thumbsup:
    Now, ive just bought a Denon 1906 and im thinking about a surround sound package from M+K. I had never heard of these speakers before but they seem to get a good review. Could anyone let me know if they rate this set up or of anything else i should know.
    Thanx
  2. rob roberts
    rob roberts
    May 7, 2006
    89
    +4
    i have the 1906 and run KEF KHT 1005's with two extra for surround back channels and it sounds really good. The KEF's are £299 from richer sounds for the 5.1 package and I picked the other two up cheap from a friend.
  3. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    M&K speakers are very good, especially if you listen more to movies than music. For movies they have the reputation of being among the very best.
    A lot of the M&K speakers are 4ohm rather than 8ohm which means they are harder to drive so favour a more powerful amp, which is something to consider.
    Which package were you looking at and what is your budget?
  4. Captain Carling
    Captain Carling
    Hi, ive ended up with a Yamaha DSPAX759SE amp and Castle compact speakers. Im really happy with this set up :thumbsup:
  5. Captain Carling
    Captain Carling
    Btw, i swapped the Denon amp for the yammy
