None UK spec CRT TV for use in the UK?
Discussion in 'General TV Discussions Forum' started by MERCKX, Feb 9, 2009.
  1. MERCKX
    MERCKX
    Dec 15, 2005
    44
    11
    Newcastle
    Sony FD Trinitron WEGA KV-27HS420
    I'm going to buy a secondhand crt tv for the bedroom, I found a Sony HDTV ready CRT TV for sale but after doing a search I've realised that it isn't a UK spec TV, US Spec? The seller is using it in this country.
    Will I have any problems using it for digital tv and sky tv in this country?
    I've had a look in the manual and it doesn't have any scart sockets but it does have component sockets and obviously a hdmi socket.
    Sony US website link for this tv
    Any help will be much apreciated, thanks.
  2. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    First thing that springs to mind is parts availabilty if it develops a fault. You could be stuck if that happens.
  3. MERCKX
    MERCKX
    Dec 15, 2005
    44
    11
    Newcastle
    Yes, probably not worth it.
    The bloke who's selling it on ebay has used a picture of a widescreen tv, after doing another search it points to the fact that it's a 4:3 ratio tv and not widescreen. :confused:
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,726
    Somewhere in South Yorkshire
    +6,300
    No reference in the spec sheet for any ability to reply 576(625)-line, 50hz material (i.e. PAL). Could be rather important......
  5. mechanic
    mechanic
    Nov 15, 2006
    289
    edinburgh
    +35
    I would suspect the owner has been using this set as "monitor" for video games , xbox or similar.This set is not designed for use in this country and in fact is fitted with a tuner unit that will not be acceptable for uk transmissions.I`ts also an ntsc video system design although not sure if this is swichable to the pal system required for here.I would give it a miss myself.
  6. MERCKX
    MERCKX
    Dec 15, 2005
    44
    11
    Newcastle
    Thanks, I will give it a miss. :)
