Non Sky+ remote with Sky+
Discussion in 'Sky Digital TV Forum' started by allen6000, Sep 23, 2003.
  1. allen6000
    allen6000
    I can't believe that the ordingary sky remotes won't work basic functions like changing channel, its shocking. I've now gotta fork out for 2 new remotes!
    Also one of my magic eye's refuses to work with sky+. Worked fine with old sky, but now won't work even though the red light is on.
    So that's another £50 for new accessories, plus an optical cable as well.
  2. Jules
    Jules
    Oct 11, 2000
    5,076
    +754
    Hold on, pretty sure you can make the orginal Sky controller control Sky plus by doing this:-
    1) Press <SKY>
    2) Press and hold <BLUE> and <SELECT> until the led flashes
    3) Press <2>
    4) Press <SELECT>
    I think thats it anyway.
    If you want to control your original box again, you press <1> in step 3.
  3. allen6000
    allen6000
    Jules,
    you've got my hopes up, but that sequence doesn't seem to work.
    Do you know where you found out about it?
  4. allen6000
    allen6000
    Don't worry Jules, I've just found it on google, its press <TV> not <sky>, although its only seems to be the TV Guide button that works, can't manually type in a channel or use search and scan.
    I'm gonna do a bit more hunting.
  5. grumpyguy
    grumpyguy
    May 11, 2002
    251
    +9
    press tv
    press and hold blue and select untill light flashes twice
    press 2
    press select
    press sky
  6. grumpyguy
    grumpyguy
    May 11, 2002
    251
    +9
    By the way, it will only change the channel up and down
