Nokia N80 Vibration really loud
Inked
I've done a search of the threads and can't find any mention of this and so i'm wondering if its normal for the vibration to be so loud.
It seems to be the slide front causing the noise as if held tight the sound dissappears. Is it a fault or is it just poor design?
scottymc
Mine's the same mate
Sliding part of the phone seems to be a tab loose bad build quality if you ask me.
M
medome
mine's have the same problem
Is that fault in my and his mobile Or it's the same in all devices ?
somebody tell me
M
medome
cracker i dont think so i heard that it has smooth vibration so i think it's fault in my phone
Similar threads
