Nokia N80 only recognises 70 tracks?
Discussion in 'Mobile Phones Forum' started by chedmaster, Aug 26, 2006.
Tags:
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I just bought a 2gb card for my N80 and the music player is only picking up 70 tracks when adding to the library?
    It says the card has 426mb free of 1gb, so I assume its missing the 2nd GB (though the phones own memory app sees all the tracks and all 2gb of the card - I can play all the tracks through gallery one at a time).
    I have them arranged in folders - could this be it? too many folders?
    They are all WMA - I fi have to I can convert them all to AAC or MP3 but i'd rather not!
    Any suggestions? Are there any decent quality 3rd party music apps to try?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I did it! I found out it only recognises up to the first GB (the music player only) So i put on 990mb, searched for music, then put a 20mb file on to pad it out to 990mb free, then put the next songs on, updated the library and it kept the first songs and found the latter songs!
    Ah, if only life was this simple!
    Anyone else had this problem or got an N80 without this problem?
