Nokia N73 playing ipod ready MP4 videos
rossyl
The N73 plays mp4's via realplayer. However it only plays certain mp4's.
i have mp4 videos that play on my pc and ipod. They do not play on my N73.
i want a 3rd party app that will be able to play them.
anyone recommend one?
if not a quick converter, that won't make the 50mb 30min videos too big, neither take long re-encoding them.
thank you
B
brooks10003
i have also nokia n 73 well i never tried to do like that which you described it earlier but i don't think that it will work well it may be plays the mp4 some song but i m 100% sure that the video will not played due to the some technicle software required problem
tvdavid
I have something on my phone which plays videos downloaded from youtube.
But I dont know if it does MP4.
The one I have is V player.
DASH232
If your using XP, the best one i used was called Nokia Media player by Makayama. But sadly it does'nt work for Vista. And its really hard to get hold of.
So i am now using ImTOO MPEG encoder and its very good. If you use it remember to set the screen size to 240*320 this will fill the whole screen.
I use it to convert AVI files to mpeg and you can watch them using realplayer.
Great when your at work and all your jobs are done.:D
Hope this helps..
