Nokia Mediamaster's digital audio - 48khz ?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by gvh, Jun 20, 2002.
  1. gvh
    gvh
    May 16, 2002
    217
    Southampton
    +20
    I have an Arcam AVR100 home cinema amp and I just obtained a Nokia Mediamaster 9850T Ondigital box (ebay). I plugged the spdif output from the nokia box into the amp's Sat digital input and got nothing. Analogue sound is fine.
    I then plugged the output into my Musical Fidelity XDAC and it switched to 48khz which was a bit of a surprise.
    Can the arcam handle such input ? No details in the manual.
    maybe the Nokia isn't outputing the correct signal.
    I know other people use the digital audio from the box as I've just trawled this forum.
    cheers
  2. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    48kHz is the correct output. It's used by MD, DVD, PS2 etc.
    You just decode the 48kHz stream using Pro-Logic.
    Your Arcam should have no problems with it, as 48kHz PCM is a standard signal type.
