Nokia Mediamaster picture position fault ???
Discussion in 'Digital TV & Video Players & Recorders' started by jackal2513, Aug 8, 2002.
Tags:
  1. jackal2513
    jackal2513
    I got my secondhand on digital Nokia mediamaster rigged up last night to my panny plasma through rgb to JS tech RGB>VGA box then into the vga plug on teh plasma.
    The problem is that after selecting 16:9 mode and rgb in the menu, the picture is actually position wrongly.. way over to the right of frame with a black bar on teh LHS. On some channels the black bar is even thicker (say 10cm) and the picture is pushed even further right.
    I suppose I could try and correct it by using teh positional controls on teh panasonic but something tells me all is not well.
    any clues or pointers would be appreciated.
    BTW: i tried going into the "PC" input settings on teh plasma and the sych and clamp position settings didn't help it.
