nokia media master on dig
Discussion in 'Digital TV & Video Players & Recorders' started by dazzer123, Dec 11, 2003.
Tags:
  1. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    is it possible to update the software on an old nokia media master on dig box to get rid of all the channels in the menu that no longer exist, i have one sitting in my loft but dont want to use it unless i can get rid off all the channel names that used to be on ondig and just get it to list the relevant freeview channels.
  2. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    Anybody have any idea?
  3. bellbrie
    bellbrie
    May 8, 2003
    23
    I think that if you just use the setup menu to find all channels, rather than "add" channels then it will wipe all the channels you currently have and just display the new channels that it finds - effectively deleting your old OnDig channels.
    b.
  4. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    This will indeed do the trick. FYI there will probably never be any software updates for these boxes so you are stuck with the old OnDigital menus and occasional lockups, etc.
  5. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    Great thanks for the info guys.
