Nokia Freeview stereo sound?
Discussion in 'Freeview & YouView' started by ian_howe@btinte, Mar 5, 2005.
  1. ian_howe@btinte
    ian_howe@btinte
    I have one of the first nokia freeview boxes, when watching analogue TV a small gret box pops up saying the channel and stereo (or mono if a mono signal) When I turn on the nokia it always says mono, and you can tell it is in mono. In the menu I have sent it to stereo. Any help much appreciated...
    Moose...
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    How is the Nokia STB connected to the TV? If it is connected via RF coax (the aerial lead) and not scart then you will never get stereo sound as RF only carries mono sound on Freeview.
    Mark.
  3. ian_howe@btinte
    ian_howe@btinte
    Its connected by scart and RF.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    If you are using the TV's tuner to receive the Freeview signal (i.e. via the RF cable) then, as stated, it WILL be in mono.
    If you don't know whether or not you are using RF, try switching it all on, watching Freeview, like you normally do. Now, disconnect the SCART. If it still works, then you weren't using the SCART (obviously). So you must have been using RF.
    If this is the case, then you need to reconnect the SCART, and work out from the TV manual, how to select the AV channel that your SCART is plugged into, rather than the RF channel.
