Nokia 7710
Discussion in 'Mobile Phones Forum' started by BigRJ, May 11, 2005.
Tags:
  1. BigRJ
    BigRJ
    Jul 8, 2004
    56
    Crawley
    I would like to find out what peoples views are on the new Nokia 7710. I will be upgrading my phone in 3 weeks and I want to get the newest phone with all the bells and whistles. My main concern is that the 7710 may be too large and vulnerable to damage on boozy nights out.
    Big RJ
    :smashin:
  2. ramseyculdesac
    ramseyculdesac
    it isnt a large model, especially when you consider what it is able to do. but im not sure i would be taking it out on boozy nights out, definately not without a cover. The touch screen whilst robust to a point probably wont react to kindly to a pint of stella over it.
    If you really want a nice pda style phone it is excellent. If you are after a rubber brick which can take fighting and a constant watering on a friday night, maybe you shoulkd look for an old eighties mobile!!!!
  3. ramseyculdesac
    ramseyculdesac
