Nokia 6680
Discussion in 'Mobile Phones Forum' started by nickthered, Aug 2, 2005.
Tags:
  1. nickthered
    nickthered
    Jun 21, 2005
    11
    Does anyone know if it is possible to use the 6680 as a webcam?
  2. fdxd
    fdxd
    Dont think so. There might a program for it however knowing the 6680. It can do anything literally. :smoke:
  3. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,148
    9
    13
    CyberSpace
    +10,678
    An application called Remote S60 will do exactly that for PC based videoconferencing...You may have to compliment it with Softcam for on the PC to scrape the screen from the S60 remote viewer...Reports state that the latest version of Remote S60 doesn't require this anymore, but I haven't verified that yet...
    Or if you are after surveillance type applications check out, http://www.mobcam.cz/
