Nokia 6630 closing applications
Discussion in 'Mobile Phones Forum' started by tapmadi, Mar 17, 2005.
Tags:
  1. tapmadi
    tapmadi
    Mar 17, 2005
    5
    Ive downloaded quite a few games from the web, the problem is when i exit the games or application I think that it is still running as everything slows down, when i try and access that same hgame again to instantly goes to the start page without loading up.
    IS there any software like where I can monitor what application is taking up what memory and how to close it,
  2. Sandman
    Sandman
    Nov 28, 2002
    3,187
    Glasgow
    +730
    Hold down the menu key for a few seconds and a list of running applications will show. Make sure you exit the applications correctly and do not just press the red button.
