Nokia 6610 abroad
Discussion in 'Mobile Phones Forum' started by jamessampson, Jul 27, 2003.
Tags:
  1. jamessampson
    jamessampson
    I know this is the best place to post this, but I can't find anywhere else:
    I'm going to Barbados tomorrow with my 6610. I'm assuming it will work, but the 02 site says something about manually selecting a band - does this just mean manually selecting a network?
    Is there anything else that has to be set up for the phone to work?
    Thanks in advance,
    James
  2. davescot
    davescot
    Hi James. If ur on o2 contract i would phone them up 2 make sure international roaming is activated on ur account, i have a 6610 too, when ur abroad ur phone should automatically register with the network with the strongest signal, however u can select manual network selection in the settings menu if u want 2 select the network urself. remember u pay 2 receive calls when abroad, hope u enjoy barbados.
    Dave
  3. jamessampson
    jamessampson
  4. davescot
    davescot
    Barbados is under the Caribbean price zone, imnot sure what the charges are but no doubt they will be very expensive. I think they have a pricing list on their website somewhere.
    Dave
  5. Cliff
    Cliff
    Mar 17, 2001
    5,795
    167
    Kent & overseas
    +3,100
    If the country uses same bands as the states you might have to switch band manually to 1900 GSM. The sim card will work OK if there is a roaming agreement - which there will be.
  6. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    The 6610 automatically selects between 900/1800/1900.
    The bad old days of manually switching Motorolas are gone!
  7. paul93
    paul93
    Dec 18, 2002
    289
    Waterlooville, Hampshire
    +6
    Mark
    Does the 6610 automatically try all the bands?
    The reason I ask is that I have had my trusty Motorola timeport tri-band for some years now and everytime I go the States I have to change the band manually. Within Europe the band selection is automatic though.
    Maybe it is time to retire the old timeport :)
    Paul
  8. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    Yes Paul.
    It will automatically scan for networks on all bands.
    When you switch it on in the USA it will find a GSM1900 network on its own just as it finds GSM900/1800 networks in Europe.
    This is pretty much standard behaviour now.
    HTH
    Mark
  9. jamessampson
    jamessampson
    Just returned from Barbados - the 6610 physically would work but 02 doesnt have a roamind agreement with the networks other there - just showed 'No access' after attempting to select a network.
    Thanks guys
    James
