Nokia 6230 - Nokia 6630 - Copying Contacts
Discussion in 'Mobile Phones Forum' started by EmissarY, May 3, 2005.
Tags:
  1. EmissarY
    EmissarY
    Can anyone tell me if there is an easy way to copy across my 100+ contacts from a nokia 6230 to a nokia 6630?
    I have tried using nokia pc suite but when I back up the files from nokia 6230, the result is unreadable by the nokia 6630.
    Else I will have to do it manually....... :thumbsdow
    Cheers for any advice,
    EmissarY.
