Nokia 6100 or Siemens C65?
Discussion in 'Mobile Phones Forum' started by Falp, Jan 10, 2005.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Hi!
    My company is changing mobile phones.
    My options are Nokia 6100 or Siemens C65.
    I think I will choose the Siemens, what do you think?
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    I think if you have a working one the 6100 is probably a great phone...I bought one second hand off ebay and have some problems with it, but that's probably why the seller was selling it!
    It's a great little phone if you like small phones, the buttons are quite small but I can still use it OK for calling/texting. Battery life is not good on mine, but again that's probably because mine was second hand. Also on mine the speaker is almost inaudible outside during calls - I suspect this is the reason it was up on eBay.
    If you can, use someone's 6100 to make a call and ask them about the battery life. If mine didn't have a knackered battery and broken speaker I'd be keeping it. As it is I'm about to upgrade to the Sony K500i.
    Also it looks like there was a manufacturer recall on the siemens c65 because of speaker problems:
    http://www.reviewcentre.com/review134257.html
    More c65 reviews here:
    http://www.mobile-phones-uk.org.uk/siemens-c65.htm
