Nokia 5530 software update
dvdguy23
Is mobile 9.com a good place to download apps. I have found quickoffice there and ovi maps but just wondering if that site is a good safe place to download from??
Also on the software update through the phone, one of the options is to install python for s60. What is this and should I install this? Would it make my phone better??
Advice will be appreciated thanks.
m.stephens
You can get most stuff direct from the Nokia site. The only app I've had which needed python (script programming language) was Scribbler which is a Windows Paint sort of thing. Unless you have anything which needs it, I wouldn't bother as it will just be taking up space.
