Nokia 3210 Voicemail problem
Discussion in 'Mobile Phones Forum' started by merlin41, Apr 23, 2007.
Tags:
  1. merlin41
    merlin41
    Aug 13, 2006
    78
    11
    Worcester UK
    Hi everyone
    I hope someone can help with a problem a friend has on the above mobile, somehow she has managed to get her hairdressers phone number as a speedial number on 1 the voicemail button. :confused: Much to the annoyance of her hairdresser all the messages are redirected to her. I can't see any access on the menu to delete or reprogramme button 1. Any ideas
    regards Terry
  2. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    not got a 3210 here to rty (you dont mean 3120 do you?)
    but the user guide says
    speed dialing settings are on call settings menu 4-1
  3. merlin41
    merlin41
    Aug 13, 2006
    78
    11
    Worcester UK
    Thanks for your reply its evidently a 3310 and the menu allows you to programme any number for speed dialling except button 1 which is not listed.
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,180
    +7,320
    Voice mailbox number (Menu 2-9)?
  5. merlin41
    merlin41
    Aug 13, 2006
    78
    11
    Worcester UK
    Thanks for the info I will pass it on and hopefully that will sort it out :thumbsup:
    Terry
