nokia 221t freeview
Discussion in 'Freeview & YouView' started by bigtank, Nov 2, 2003.
  1. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    anyone else have problems with this unit
    it always freezes and has to be unpluged to reset it.
    my aerial has been checked and is ok.
    have had unit replaced by currys and still the same problems:mad:
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Tried it when it first came out, despite high praise and glowing reviews I took it back straight away.
    Try latest Philips, Sony or new twin scart Panasonic instead.
  3. PhilipVass
    PhilipVass
    I suggest you return the receiver as they are renound for crashing also they are very overpriced.
  4. rosemanbridge
    rosemanbridge
    May 24, 2002
    257
    I had two of them on the recommendation of Home Cinema Choice. Took 'em both back due to locking up and/or freezing the picture. Swapped them for the Pioneer which is superb.
  5. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    thanks for the advice
    took it back and got a full refund
    what will i replace it with as i have lost faith in the freeview technology
