Nokia 221T card slot
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jerry, Dec 16, 2002.
  1. jerry
    jerry
    Jan 6, 2002
    421
    london
    +18
    Just bought the 221T and initial reaction is good. My analogue picture is good and the digi reception is as good but not better. Signal comes via a 27 year old ariel on c. stack into a 32" Phillips DD TV which through the Nokia gives occaisonal over processing when there is a lot of quick movement. The 221T has a slot for a card, is there currently any card available which will increase the number of channels, either legit or not quite so?
