Nokia 221- sw update today!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dazwaldo, Jan 30, 2003.
  1. dazwaldo
    dazwaldo
    Jan 6, 2003
    1,085
    63
    +141
    I've just downloaded the SW update this morning, took about 10 mins.
    Only change I've noticed so far is correct 'widescreen' format switching between channels now. Not sure if freeze-up/crashing prob is fixed....time will tell.
    Downside is you loose all you fav listings on installation.
    Anybody else noticed any improvements??
  2. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    Yes.. it is relevant to people with other Nokia equipment. I also have a Nokia 9600S digital satellite receiver. The 9600S remote control was also switching on the 221T! The software upgrade today has fixed that.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Is this an "over air update" Or PC download,as I have a nokia Ondigi box and need to know what to do if i can get the update
    Cheers HD
  4. bobones
    bobones
    Jan 15, 2002
    453
    +7
    It's over the air and for the Nokia 221T box only.
