Nokia 221 STB crash
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Papa Smurf, Dec 19, 2002.
  1. Papa Smurf
    Papa Smurf
    I got mine late last night, and guess what, after watching it for about an hour - it crashed. I had just switched from teletext mode into tv mode, and the image froze. None of the buttons seemed to do anything. In the end I had to power off.
    Does anyonre know if this is a known bug - or should I get a replcement ?
  2. artgar
    artgar
  3. leeoh
    leeoh
    Nov 11, 2002
    111
    16
    Buckinghamshire
    Got mine last night also and guess what - yeph it crashed. going into TXT mode too soon after changing channels. Had to power off at mains to reset the box. Looks like a software bug, for sure its not a hardware problem. If you wait 5 seconds after changing channel then hit TXT its OK.
    Picture though superb, no freezing, no glitches and on 30% signal strength according to built in meter. A better STB than the Grundig I had before.
  4. Papa Smurf
    Papa Smurf
    Lets hope the software upgrade fixes the bug.
    Whilst I'm here - I've noticed another problem. When I watch my tv via analogue rf signal, the picture (brightness/contrast etc...) is very good. However, when I switch the Nokia on, the picture is very very bright and the contrast is also very high.
    In fact if I turn the brightness and contrast down to zero on my tv, I can still see a picture via the Nokia (its almost totally black via analogue). I'm not sure if this is due to the Nokia, the supplied SCART lead or perhaps the SCART interface on my tv (a 14" panasonic portable).
    Anyone got any ideas ???
