Noisy PSW2000
Discussion in 'Subwoofers' started by nickthesafe, Jun 9, 2004.
  1. nickthesafe
    nickthesafe
    Hello group....this is my first post so be gentle!
    I have a kef psw2000 which, after a few minutes of being switched on, emits a high frequency (low level) whistle accompanied by white noise. The wierdest thing is that the noise also makes it's way back to the amp (DSP-A2). Unplugging the coaxial cable shuts off the noise to the amp but the sub continues to misbehave. Sometimes during quite scenes the high frequency rises sounding like a distant siren, and then the sub switches to auto off with a thud. So far kef have been helpful and are willing to send me out a new amplifier unit for it, but it would be interesting to find out if anyone else has had a similar problem, is it common?.
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Try another sub cable ? Does the sub make any noise when no cables are connected ??
  3. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    This sounds like an amp problem.........Capacitors sound like that, when they are on there way out. Dont know how its getting back into your amp, maybe its a problem in the signal stage of the sub.
    Kef must think its an amp problem, as they are willing to send you a new amp. Substitute a new cable just in case. But Id put bets on a cap in the amp going tits up.
  4. nickthesafe
    nickthesafe
    :clap:
    Would you believe it!, KEF sent me out a replacement panel so i could just swap the thing over. The modded one had two tranny's and two resistors moved to the main heatsink. Strange thing was it kept making the same noise, So i figured the problem was elsewhere. Lived with it all this time until just yesterday i had a bit of free time. Here's the result of a little probing and testing: U14 and U15 on the main board were getting too hot and introducing a random square wave into the audio signal. I moved both devices to the heatsink - PROBLEM SOLVED.
  5. dandini
    dandini
    Jun 26, 2007
    184
    +9
    Hi Nick,
    U14 and 15 are regulators - is this what they moved? I'm curious as you mentioned resistors and transistors, not regulators?
    Any chance of a photo of your modded one?
    Thanks,
    Dan
