noisy panasonic 42"pw5 plasma
Discussion in 'Panasonic TVs Forum' started by jjwd, Aug 28, 2003.
  1. jjwd
    jjwd
    I have had a pw5 for a few weeks and its brilliant
    The only downside of the screen is a high pitched noise that seems to come from the bottom left of the screen. I have the 'export' model and was wondering if it was a voltage issue?
    Could one of those voltage smoother plugs help or are they a bit of a con?
    It may just be that I have good hearing as my girlfriend cannot hear it very often.
    Any help / advice would be greatly received
  2. edonkeyman
    edonkeyman
    Jun 17, 2003
    10
    London
    Hmmm it seems your not alone, I too am experiencing crackling noises coming from my panny pw5.
    Is your plasma mounted??? The noises have started since I had the plasma mounted on the wall, mine is the non-export model i.e UK model.
  3. jjwd
    jjwd
    yes mine is wall mounted - it sounds a bit like a fridge or fish aquarium at times and is quite a high pitched noise. I took the first screen back to the shop and kicked up a fuss and was given a new one. I felt like an arse when this one did the same thing.
    I think its something to do with the transformer or the video card gubbins.
