Noisy Fan Teac AG V-8520 receiver
Jackson1181
The fan in our Teac AG V-8520 receiver is noisy all of a sudden. We took it apart, and the blades in the fan are not hitting, so we feel it is the motor. We cannot find Teac replacement parts online. Can we substitute another fan motor? Any suggestions would be appreciated!
fxv300
Is the fan made by TEAC? With fans they are usually easy to substitute. They are only a few quid each new. When they become noisy it usually is the motor. I have a box full of them from laptops, PCs and all sorts of things. They are mainly 12V or 6V and 3 or 4 pin to connect. Post a picture of what you have, there is normally a label on the fan motor.
Upvote 0
Jackson1181
Upvote 0
Jackson1181
Thank you for your reply! The motor only has 2 pins and doesn't specify the voltage.
The number on the side of the motor is: MDN4RB4MRC
We have tried searching the number and it only shows as unavailable.
thanks!
Upvote 0
fxv300
I see from the pictures it has unique fitting lugs etc, probably best to contact TEAC support unless you can find something online which can do the job. If you search google for MDN4RBMRC which is from your picture you will find lots of hits, looks like that fan is also used on Technics and Panasonic kit. Hope that helps. You will need to solder it in place so make sure which wire goes where if you ever get one. Good luck.
Upvote 0
Toy Stories - Turning Toys into Blockbuster Movies
