Noisy DVD drive
Discussion in 'Desktop & Laptop Computers Forum' started by Phoenix_TT, Mar 20, 2006.
  1. Phoenix_TT
    Phoenix_TT
    Hello
    Anyone got any advise on how to silence a noisy DVD-RW drive ?
    Regards
    Geoff
  2. throwit
    throwit
    Jan 30, 2006
    521
    +14
    are you getting washing machine spin cycle noises ? sometimes these drives seem to go into hyperdrive, and unless firmware updates or changing write speed might help, the only thing you can probably do is put your drive or pc in something else, as far as i know there are possibly dampening mounts, but it seems to me that they won't work all that well as the fitting screws will still transfer the vibration through to the chassis
    someone else may know better
  3. Nick Cartwright
    Nick Cartwright
    If you want to quieten it for Playback then Nero has a utility (Drive Speed or something) which alows you to set the read and write speeds separately, plus the spin down time (so it is not constantly slowign down and speeding up).
    I use this for my LG drive and run DVD playback at just 2x which is near enough silent.
    If it is a Pioneer drive then they have their own utility called DVDUTIL (I think). This will do a simillar job.
    Both alow temporary speed up so you can extract data/programs at fll speed and just slow it down for DVD watching.
    Hope this helps
  4. mavice
    mavice
    Dec 8, 2004
    400
    Devon UK
    +16
    AnyDVD by SlySoft also does this (Icon pic of a fox)
    lets you select dvd drive speed for playing data, music or film seperately.
    eg, film - slow and quiet, data - fast & noisy
    Lets you skip the krap at the start of DVD's too
  5. avanzato
    avanzato
    Jan 21, 2003
    1,970
    Norfolk
    +83
    I had a Samsung that even with the AnyDVD speed control was a noisy PITA so swapped it out for a NEC that's quiet without using AnyDVD.
