Noisy Blacks on PW7 - normal?
Discussion in 'Plasma TVs' started by lisag, Mar 20, 2005.
  1. lisag
    lisag
    Jul 14, 2004
    5,878
    Essex
    +367
    Still tweaking.....
    When doing brightness/contrast adjustments through the DVE disc if I get up really close to the screen, I can see 'noise' in some of the bars of the grey. Changing the contrast/brightness settings moves the noise around. I can't seem to get it to disappear completely though.
    I suspect - professional callibration is the solution, but I can't afford that so just some general comments on this would do for now.
    Is this normal?
    When sitting at normal viewing distance it isn't really noticeable unless a large area of the screen hits that particularly shade of grey, then the noise is apparent (to me).
    thanks
    lisa
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    What you're describing sounds like "dithering".
    Most, if not all, plasma screens suffer from this artifact. Professional calibration may reduce dithering, but I don't think it can be completely removed.
    Cheers.
  3. PeteJ
    PeteJ
    Mar 21, 2005
    I have it to on my PW7. Didn´t see it at first. Like you i had to go up really close. Seen it on DVE and the THX logo. Looks like ants crawling around ;)
    Got the HDMI card and the noise just exploded. Did alot of tweaking in DVE before i got happy. Now it looks great but i do see it sometimes. My own fault because i look for it when nobody else can see it if i don´t point it out :rolleyes:
  4. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Where does one get a DVE disk??
    Am in Dublin, Ireland.
    Cheers :thumbsup:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
