noisy blacks help!!
Discussion in 'Projectors, Screens & Video Processors' started by gorwig, Mar 31, 2005.
  1. gorwig
    gorwig
    Aug 2, 2004
    202
    Abertawe
    +13
    I have a problem with very noisy on screen blacks and a degree of mosquitos, especially around white titles on black backrounds. The picture looks relatively clean on bright scenes, but on dark scenes the picture is not very pretty with a lot of random white noise in the blacks. I am using a sp5700 PJ fed from a Yamaha S540 dvd player via progressive component. I have manufactured my own cables from psf1/3 coax with gold Deltron phonos, they are about 10m long.
    I read Gary L`s suggestion about running DVE in another thread, mine is on order, but my problem seems to be greater than a bit of bad setup. Any ideas would be most gratefully accepted!!
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    Are there any test images available from the projector that you can use rather then a input source so you can check if its the feed or the projector?
    On my DLP PJ I see noise on blacks if viewed closely but it dissappears at normal viewing distances.
  3. gorwig
    gorwig
    Aug 2, 2004
    202
    Abertawe
    +13
    Thanks, I`ve had a look at the chequered square test pattern and it looks gorgeous with deep clean blacks and bright whites. So at least I`ve narrowed it down to the source now.
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,186
    Scotland
    +170
    Have you got a plain black test screen you can use.
  5. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,154
    Surrey. UK.
    +1,956
    Do you have any THX disks with Optimode? (Star Wars eps 1 and 2, Cast Away for example) You could try one of those to get you in the ball park calibrating white and black levels, and then you'll see if you can remove the mosquito noise. That will do until you get DVE.
    Gary.
  6. gorwig
    gorwig
    Aug 2, 2004
    202
    Abertawe
    +13
    Thanks for your input chaps. I`ve had a little play with the THX bit of Star Wars Episode 1 and after a bit of tweaking it does seem much better. Hopefully DVE will be here soon and I can finish the job.
