Noisefloor?
Discussion in 'AV Receivers & Amplifiers' started by vallhall, Jun 18, 2004.
  1. vallhall
    vallhall
    May 21, 2004
    195
    Norway
    +16
    Hi ppl
    Well, what is noisefloor?
  2. KEF Ben
    KEF Ben
    Dec 11, 2002
    10
    3
    KEF
    In short, noise generated by the electronics.
    Noisefloor usually doesn't change with volume, although you often get a hiss at higher levels, this could also be described as noisefloor.
    Put your ear against your speaker with nothing playing.
    Can you hear anything?
    If you can this it is the "noisefloor".
    A high S/N ratio means the noisefloor is lower and should not be audible.
  3. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    I found that I never knew what noisefloor was until I upgraded the soundcard on my PC and listened to DVD-audio; then I realised what I wasn't hearing, if you know what I mean.
    You probably have to hear it for yourself to truely understand what a difference it makes...
  4. vallhall
    vallhall
    May 21, 2004
    195
    Norway
    +16
    Many thanks ppl
    I thought it had something to do with hum/hiss in amps
  5. wookie
    wookie
    Yeah, Can't beat a nice BLACK sound in a system
