Noise
Discussion in 'Photography Forums' started by kentether, Mar 10, 2003.
  1. kentether
    kentether
    I am experiencing excessive noise on printing out, at any size, from shots taken with Fuji S602, particularly in the shadows. I am using PSPro together with an Epson Stylus 810 printer,. Can anyone offer suggestions.
  2. BigAardvaark
    BigAardvaark
    Feb 25, 2003
    395
    North West England
    +66
    Only thing I can think of would be to check you've not got the ISO setting of the 602 set too high? I pretty much run mine permanently at ISO160 which is the slowest setting it has. I wouldn't shoot any higher than 400 without EXPECTING quite an obtrusive amount of noise.
    Hope this helps,
    Ian.
  3. kentether
    kentether
    Tks for your help.
    Generally the ISO setting is default ie 200 but I am continually experimenting in the hope of finding an equitable solution for grab shots.
  4. minimad
    minimad
    This mount sound like a dumb question, but:
    do you see the "noise" when viewing the picture in PSP?
    If it was the camera being st wrong then I would expect to see noise at every point where I viewed the picture, eg, on the camera screen (I understand that this isn't always easy), in PSP on the computer and when I print the picture.
    If not, then I would suggest looking at your printer settings. perhaps the DPI rate is too low for a decent quality picture?
    Collin
