Hello all!
Having recently moved into a new apartment overlooking a main street, I have pretty serious problems with noise from the three (lovely looking) single glazed sash windows in our front room, each being 100 x 185 cm to the frame edge.
Currently covering them are some wooden blinds that the landlord put there, so removing them is not an option. I suspect these may be adding to the problem by resonating in line with the noise coming from outside.
So my question is the best solution to this problem.. Obviously I'm not going to get silence, but at the moment my hi-fi sounds dreadful from the pollution. Having done some research, my options are:
- Put a heavy material curtain behind the blinds. My research seems to suggest that velvet will have the best sound deadening effect; any thoughts on this?
- Put heavy velvet curtains in front of the blinds.. (More expensive and also not likely as good aesthetically)
- Put a double/triple layer of thinner (cotton?) curtains in front of the blinds using a double poled hook from Ikea.
- Back the curtains with some ultra lightweight sound deadening (Thinking of Dynamat extreme)
In addition to this, the windows seem to rattle quite a bit on low frequency sounds. I thought of putting draught proofing around the opening part; any thoughts on this?
