Noise Issue- comments welcome
Discussion in 'Photography Forums' started by longleyc, Aug 24, 2005.
  1. longleyc
    longleyc
    I come across a weird situation regarding noise. A lass in my digital photography class mailed me the shot to analyse it. I never seen a case this bad. I had to reduce the size to 120kb to upload so I think the hot pixels will be evident.
    The attached picture shows some noise that I would expect from a cheap camera, low lit poor focus shot. That noise is evident. What I find strange are the 4 -6 pixels areas that showing up white/blue/red.
    My guess is the ccd is becoming faulty due to either:
    Thermal noise on certain pixels due to the heat within CCD.
    I might get her to shoot a shot covering the lens and examine by dark frame extraction process.
    Electronic Noise. If the CCD is failing then the stray capacitances might be causing these multi pixel noises. That might explain a signal to noise ratio problem.
    My thinking here is that some of the individual ccd sensors are being overcharged and causing multi hot pixels in the image. Exact cause: Unknown.
    Heat? CCD design? poor noise algorythm?
    I dont think its dust on the CCD or lens as there are red and blue pixels too.
    Comments please.
  2. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    what camera? settings etc?
    should she really be posing like that :thumbsdow
  3. rhardaker
    rhardaker
    Mar 11, 2003
    384
    West Yorks
    +15
    looks like a camera phone to me!
  4. MattB1
    MattB1
    Looks OK to me :D
  5. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    model is fine, as said, its a cameraphone or webcam!!!
    what sort of classes require shots like that?????
  6. sorbiegunner
    sorbiegunner
    Jan 16, 2004
    184
    I assume you're the teacher of this 'digital photography class'. I'm afraid to say that anyone who mentions 'dark frame extraction process' in any context whatsoever is a wee bit to advanced to benefit from my advice/comments, but for what it's worth I'd plump for a combination of poor lighting and bad equipment as being the main culprit.
    I'd definitely forget all about capacitancies and the like, that seems like a subject more suited to a digital camera fixing class to me.
    As for individual ccd sensors being overcharged, it's difficult for me to tell as I was charged for a bulk lot of millions of the blighters and I've never bothered to work out what the charge for each individual one would be, also you'd have to know what percentage of the overall amount she was charged for the camera was put down to sensors. :D
  7. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Not sure anybody's checking the noise out:laugh:
    Really does looks like a web cam shot
  8. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Wonderful Breasts..... :rotfl:
  9. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Some serious barrel distortion there:laugh:
    Seriously though, she sent you that :eek:
    I think the biggest noise in that photo is that it's screaming, come get me:laugh:
    She's got to fancy you mate
  10. longleyc
    longleyc
    Heh guys!
    Thats tame! But I wont post the other sexy snaps. Not dirrrty pics (I wish) but sensous. Sadly, she likes me for my brains but not where my brains are kept!
    So my technical post hasnt got too far. :)
    Sitting here thinking made me realise that I think they are hot pixels and they are tending to show on her shots in low light without a flash. I guess the cam ups the ISO in auto mode thus causing the hot pixels on a crap digital camera. Amplification of the signal is what gives you a higher ISO and the charges leak onto adjacent photosensors above the "noise floor". Severe cases causes noise and abberrant hot pixels.
    So if you see this, you know what it is :)
  11. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    make up girl (no seriously theres a clinique box next to her...)
    as i said, what settings camera etc
    it could just be a crap camera on the highest ISO, we need to know.
    looks buggered, show up unanouncec and show her your extensive zoom capability and let her play with yours.
    i mean camera, you dirty minded individuals
  12. longleyc
    longleyc
    Okay mrjones, she said this ones for you.
    Its a cheapo Kodak camera. Ill suggest using the flash and lower ISO`s.
  13. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    check out the size off those oranges!!!!!
    (does she know your posting pics of her on tinternet?)
  14. longleyc
    longleyc
    No!
    End of thread.
  15. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
