J90RDN
Established Member
Have purposly ignored the PS3 since it's launch as without GT5 the PS3 didn't really do anything I wanted that a 360 couldn't do, but now obviously all that has changed!!! So
Are there any differences between all the different versions, aside from one being fat, one being slim, and the miriad of different hard disk options? All I will be after is a PS3 to play GT5, nothing more. I'd like to hook it up to the internet for online gaming and updates. It would be useful to play old PS2 games on it, but not essential as I don't mind keeping the PS2 hooked up if needed. It would also be nice to hook up a wheel of some description.
I've made the assumption all PS3's are HDMI?
Also, if buying second hand, what are the major problems (i.e. 3ROD equivalent) and are there any tell tail signs to avoid?
I'm not going to hack it, so not too bothered about firmware versions etc.
Also, can the old DVD remote for the PS2 be used on a PS3?
Some general advice would be grand.
