no video on vga only
Discussion in 'Xbox Forums' started by lucas22, Jan 19, 2008.
  1. lucas22
    lucas22
    Jul 22, 2007
    254
    Northern Ireland
    +8
    hi i have noticed that some avi videos streamed to the 360 will only play via compnent at 50 hz,as i prefer vga is there any way of getting round this problem.
    as always many thanks.
  2. lucas22
    lucas22
    Jul 22, 2007
    254
    Northern Ireland
    +8
    anyone!!!!!
  3. Darkad1
    Darkad1
    Jul 15, 2007
    13
    I have the same problem.
  4. Grumpy Boy
    Grumpy Boy
    Jan 4, 2008
    121
    Llanelli
    +10
    I think all VGA inputs into TV's are set to 60hz.
    However, I have come across a "fix" that may work.
    My mates LCD tv would not let him switch to 60hz when using the standard composite cable. So he could not play some of the arcade games pre-loaded on his 360 nor some games he bought (all required 60hz).
    His LCD TV was HD but only had the VGA socket - not component or HDMI. I got him a VGA cable and set up the PC settings on his TV/360 and we tried a bought game that played very well. However, when we tried the pre-loaded games they would not play - saying they required 60hz.
    So, we re-connected the old cable, set the 360 to 60hz, re-connected the VGA and bingo it worked.
    It seems that the 50/60hz settings are held/detected in two different places?.
    Basically, (this may or may not work)....re-connect your old cable, set TV to 50hz, re-connect your VGA lead and try it.
  5. sordid_sentinel
    sordid_sentinel
    Mar 31, 2007
    2,062
    +487
    Setting your resolution to 640x480 before you watch a video will make it play properly and is a temporary fix 'till Microsoft sort it out (problem only happens with pal machines afaik).
  6. Darkad1
    Darkad1
    Jul 15, 2007
    13
    Right, thanks.
  7. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    Hitting the Eastside of the LBC
    +1,649
    put the component cable back in
    in settings put the display back to regular resolution (think it is 576?)
    press yes to display this
    when it say does it display 50/60 hz correctly press no
    put vga back in and will work fine
  8. Darkad1
    Darkad1
    Jul 15, 2007
    13
    What do you mean regular resolution? With component, the choices are 480p, 720p and 1080i.
  9. Darkad1
    Darkad1
    Jul 15, 2007
    13
    Thankyou so much, it worked!
  10. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    +1,649
    yeah 480p that was it!
    glad it worked, had me puzzled for ages till i figured it out!
