No(va) sound on the left
Discussion in 'Home Cinema Buying & Building' started by fatmatt, Oct 1, 2004.
  1. fatmatt
    fatmatt
    hi all
    got the eltax nova a little while back but have only had it set up for a month. i noticed last night that when watching the telly through it i have no sound from the left channel. I tested all the other inputs and there fine on all channels. is it duff or am i doing something stupid. Its still in warranty but i dont want to look a twit when i take it back.
    ta
    matt
  2. fatmatt
    fatmatt
    I have just tried a different scart lead. i have now got sound from both fronts but none on the rears. are scart leads all the same or do some have less connections??
  3. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    They are not all the same however they should all have the audio (only L&R) connected - RGB only exepted which only carries video signals.
