No UMD in box?
Discussion in 'PS Vita Forum' started by fozziebear39, Sep 1, 2005.
Tags:
  1. fozziebear39
    fozziebear39
    Jan 3, 2003
    993
    Newton-le-Willows
    +43
    Didn't get a demo disk in pack so can't update to 2.0. Rang Sony said go back to retailer. In meantime I can download it.
    Where is 2.0 UK version? Anyone know please? It's not on www.yourpsp.com
  2. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    If you bought your psp from the UK it comes preinstalled with version 2.0 doesnt it? If its an import you need to install the appropriate region update.
  3. drskhaled
    drskhaled
    Feb 25, 2005
    1,541
    London
    +108
    no it comes with v1.52 preinstalled, the demo disc has the 2.0 upgrade. The demo disc is cr4p, all video and no plyable demos.
  4. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    OK in that case I would try the north american update on it as far as I can see it works on the UK model. try the gamespot website at www.gamespot.com they have a big PSP section and probably have the answer, they've said the updated patch works on regions its not meant to but then that is a risk that is up to you. Failing that borrow the demo disk off someone, if you don't know anyone with a PSP ask someone on the forums, I'm sure someone will give up theirs. Afterall it's just a demo disk.
  5. fozziebear39
    fozziebear39
    Jan 3, 2003
    993
    Newton-le-Willows
    +43
    Thanks drskhaled, that's all I needed to know. Won't bother chasing it up now. Got the update to work now, (server was down before) just clicked on update and it downloaded 16Mb to memory card and I've run it and now on 2.0
    :hiya:
