No Surround Through Sky Help!
Discussion in 'Plasma TVs Forum' started by Ross-P, Aug 20, 2005.
  1. Ross-P
    Ross-P
    Mar 16, 2005
    400
    UK
    +25
    I'm probably not doing something really simple! but here is my problem-
    My set up is-
    LG PX11 Plasma
    JVC THR3 all in one recordable DVD surround system.( amazing value by the way! :thumbsup: )
    Panasonic Digibox (5.1.B ?)
    I can get surround sound when I play a DVD, but can't get surround through sky. :confused:
    do I need a sky box with a coaxial or optical lead (a connection which my sky box dosen't have!) and connect it to my DVD system ? :confused:
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you should be able to get surround sound with the red and white stereo connectors but you will only get digital surround with the optical connection (but that is only for movies 1,2 and 3 anyway)
  3. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    hasn't it got to be sky+ though
  4. Ross-P
    Ross-P
    Mar 16, 2005
    400
    UK
    +25
    Thamks for that I will give it a try :smashin:
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Make sure the sound output on the Sky box is set to STEREO.
  6. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    audio output = stereo
    optital output = dolby d
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes
