No subwoofer sound
Discussion in 'Subwoofers' started by Chorea, Jan 21, 2002.
  1. Chorea
    Chorea
    Jan 16, 2002
    261
    +6
    I bought a Kenwood krfv5050 over the weekend and think it is excellent value for money but i can't get any sound from my subwoofer (kef coda S). I have it plugged into the subwoofer output on the amp and in one of the low frequency inputs on the subwoofer.
    Please help
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    Has the Kenwood got the option to turn on/off the sub output?
    You should also have options for the speaker configuration, small/large & subwoofer yes/no also the ability to send the bass to the sub/both or main speakers.
    Check you´ve got these set up ok.
    If you have, also check the cable, try another one just in case its that.
  3. Chorea
    Chorea
    Jan 16, 2002
    261
    +6
    Cheers mate i will have a look when i get home. The cable supplied is a bog standard phono cable is this o.k??
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    Yep! Bog standard phono cable is ok.
    You can upgrade to better cables if you want to though, but I wouldnt go too mad.
    I use a run of Chord Chrysalis cable, about 30 quid for a 3m length.
