No Sub in Pro-logic II
Discussion in 'AV Receivers & Amplifiers' started by CrispyXUK, Dec 23, 2003.
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    Land of the Living, Essex
    +45
    Erm for some reason my amp has stopped outputting anything to the sub in PLII mode even though sub volume is set to 0, if I change to DTS/NEO:6 I get sub action.
    Any ideas?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    Rather odd.:confused: Doublecheck the Channel Levels (SW) but the Denon usually classes PL2/DTS Neo etc as one format. The only thing I can suggest is to do a processor reset which means holding the PCM and AUTO buttons on the front panel whilst turning the Power ON (the display will flash and reset everything). If you do this then write down ALL your settings beforehand i.e Channel Levels, Delay Distances, Digital In Assignments etc so you can key them back in again quickly.
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    +45
    cheers mate will give it a go
