No Space For Centre Speaker
Discussion in 'Home Cinema Speakers' started by Venomx999, Dec 26, 2017.
  1. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    Hi, i have an LG 4K TV and i have the centre speaker behind the TV as the gap below the TV is literally 2-3 inches so there's no space for the centre speaker.
    Will i just have to be content with it behind the TV
    thanks
  2. mossym
    mossym
    Apr 5, 2006
    13,174
    Ireland
    +2,817
    No , just run a left/ right and they will take care of the center duty
  3. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    So you mean the Front Left and Front Right ?
    Having The centre speakers behind the TV doesn't affect the sound that much
  4. mossym
    mossym
    Apr 5, 2006
    13,174
    Ireland
    +2,817
    Yes, they will give a phantom center that will sound just as good if you are sitting between them, the center is largely redundant then
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    As above remove the centre and just run 2 speakers up front.
  6. mbmapit
    mbmapit
    Feb 15, 2005
    1,905
    Stansted
    +435
    What about mounting above the TV angled to your MLP? It isn't ideal but IMHO I'd rather this than settle for a phantom centre channel.
  7. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    The TV is thin and the speaker is thick, i can place it on top of the TV but i wouldn't want it to fall
  8. jont
    jont
    Apr 8, 2002
    4,337
    near Aylesbury
    +577
    Put some kids wooden play blocks (or something more aesthetic) under the feet of the stand and lift the tv a couple of inches ?
  9. mossym
    mossym
    Apr 5, 2006
    13,174
    Ireland
    +2,817
    OP, where do you sit in relation to the TV?
  10. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    Square on, about 2 metres back
  11. mossym
    mossym
    Apr 5, 2006
    13,174
    Ireland
    +2,817
    reason for a center is to lock voices to the screen for people sitting off center. As you aren't the phantom will work fine.
  12. mbmapit
    mbmapit
    Feb 15, 2005
    1,905
    Stansted
    +435
    Floating shelf above TV? Raise the TV with a different bracket/stand and position the centre below the TV?
  13. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,158
    +1,818
    It depends also on the room layout. If you sit 2M back, then your left and right speakers only need to be about 1.5M apart to give good imagery and a totally acceptable phantom centre. If your speakers are set wider than about 2M, then the centre speaker helps to focus the vocal track more and is a bit more necessary. I wouldn't want it behind the TV though, as the reflections from the back would add to the direct sound and give weird phasing and other effects.
  14. RiseAbove
    RiseAbove
    Aug 12, 2015
    706
    UK
    +373
    Is there issues with having the centre speaker above the tv, above listening height?
  15. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    Yes it could easily fall off as my tv is very thin
  16. Venomx999
    Venomx999
    Apr 30, 2017
    575
    46
    UK
    +131
    I’m happy with it the way it is anyway. It’s very clear and audible
