No Sound!!!!!!!!!!!!!!
R
rimshot
Help!!!!!!!!!!!!!!!!
Trying to record from my old camera analogue footage
Using Cyberlink power producer, can record video but can't get any sound, tried windows movie maker, same problem, connect up my dv camera with firewire no problem.
It was all working perfectly the other day, I have a connect all drive, you hear sound when playing the camera through the inputs all sounds well, play back no sound!
I have the sound cable connected to the blue port, configured as line in?
Can find no answer in the fault finding files
Roger
melliott1963
I think that through both these programs you can set which audio port you are using. Check that it is set to Line-in. If, however, this is what is already set, try changing it to Aux.
I know I've had similar problems with analogue audio inputs, and playing around with the settings gets there in the end.
R
rimshot
Tried that! tried everything, was working o.k. the other day. I have tried recording from a cd player, hear the sound but nothing on playback, can't figure it!
Roger
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
