No sound with Dolby Digital
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Woolybully, Mar 29, 2005.
  1. Woolybully
    Woolybully
    May 6, 2002
    257
    Bradford
    +8
    HI
    Has anyone had the problem of no sound on DD broadcasts?
    I recorded Batman Forever on Sky Movies the other night and found that it had no sound I then checked the other movie channels and found that all movie channels broadcasting with a DD soundtrack had no sound...the ones with no DD had!.I Checked my settings and my optical cable and all seemed fine.By the way,if I switch to normal stereo from DD on Sky+ box,sound returns but only as stereo.
    Any Ideas...has my box gone faulty? :confused:
  2. markbingo
    markbingo
    Nov 10, 2004
    819
    46
    Cambs
    +124
    I have not had this problem myself. I taped a couple of DD movies over the weekend, and they came out fine. I connect via optical cable to my 5.1 system.
    FYI, I did NOT record Batman Forever, so can't confirm if that particular broadcast was ok or not.
    I would suggest that you do some more testing, with the sound on different settings and make sure all your cables are seated correctly. Optical cables are not a very firm fit, so are you sure its in ok on both ? Does your 5.1 confirm it's receiving the Optical signal during playback ?
    Mark
  3. sinbrad
    sinbrad
    a little more help maybe ie what setup do you currently have (amp/receiver etc)
